K5dreamer
Quick one - while searching the forums on my injector question, i stumbled across a bit of info i was unaware of. early 6.2's used cast rocker arms, and 86 and newer used stamped.... is there a benifit to the cast ones? if so, are they a direct swap for the stamped ones on my engine?
Ok, injector question. My M1009 dosnt have that many miles on it, only about 70-75k, but it is 23 years old, and has probably spent alot of that time idling, so ive decided its time for some preventative maintanence (before i burn a hole in a piston or something), and im debating having the IP and injectors rebuilt. regarding the injectors, i know alot of VW and Mercedes guys install modern updated nozzles with more holes, and better spray patterns for both more power and better fuel economy. usually this also means less black smoke and smoother, quieter running. Anyone here do this, and have a specific nozzle size or part number they reccomend? maybe using marine, or 6.5L nozzles? or some other random bosch part number?
