Injector/fuel line problems
mill5471
Metamora, Michigan
Vehicle is an 85' GMC C30 with the 6.2. Got rebuilt injectors and went to change the old ones out and could only change three. Two problems: 1) can't get socket over passenger side rear injector because of A/C. Im thinking the black A/C cover is going to have to come off. 2) All of the injectors on the drivers side turn before the fuel line breaks loose and i don't want to twist the hard fuel line. Over the last few days i had been spraying the fittings up with PB Blaster, i just went out to try them again and had no luck. I also tried holding the injector with pliers and then turning the fuel line fitting but had no luck either, as it is pretty tricky to with a oil dipstick, master cylinder, brake lines, steering shaft and A/C pump all in that area. Any suggestions?
Buy the correct size wrench that fits the injectors. It should solve both problems.
30 mm is the correect size for the injectors. I was able to re&re all the passenger injectors using a deep 30 mm socket, and my truck has AC too.
Rene
