Inline tube fuel line
wazzabie
Washington State
Got the fuel lines from Inline tube today for a 78 K5. The lines are longer then mine. Also they loop back where the fuel pump connects. My lines do not have a loop. I'm installing the lines with the body and engine in the K5. I was able to remove the fuel lines so I should be able to reinstall them. However because of this loop on the end I'm not able to pass them through the engine mount area. Anyone else have this problem?
My lines were different, but I was able to remove the front bumper and slide the non bent end in through the motor mount area and all the way back. You might try something like that.
