kirkallen143
Registered Member
Howdy fellers,
How hard is it to change the inner guides on a 10 bolt? Are they basically just a needle bearing? The needle bearing was shot on the pass side spindle and it wasn't too hard to get out, but the inners look like a different story. Do you really need them (well I know you do), but this burb see mostly 2WD and is rarely in 4WD, only when necessary. This is on the pass (short axle) side and was wondering since the one axle end already rest in the case in the spider side gears, if it would suffice. The other side looks like it is all intact.
Appreciate any and all replies, thank you.
Kirk
Kirk
