Inner fender coating
rgretzinger
Longvew, TX
I was wondering what you use to coat the inner fenders? Paint, bed liner or some other coating, etc? I need to replace the front right and figured I might as well take care of them all.
I don't know what everybody else does, But I just use Rustoleum in flat black. I can just touch up when I need to. Not very often though. Good luck!
That bed liner in a can seems to work well
I have used 3M undercoating spray, the rubberized stuff.
Same here the new ones I got I sprayed two coats before I put them on. I did the lower inner by firewall and went up till hinge area. Then did the flat part in the front where my batteries were. I then put three coats on the under side of it.
Seem to worked OK I still need a stove bolt where the jack screw went to block water spray.
