Inner fender install
TJ1978
I have MANY questions
East Valley, Arizona
I have the front end bolt kit but this bolts washer doesn't hold the fender the cab. The passenger side seemed to work but driver side the washer seems to small the clamp against the inner fender
Unless I'm hanging the passenger side fender incorrect
How does this core support fender piece bolt in?
If anyone has the time to talk, or face time let me know I'm sure it would be quicker
The fender brace is in correctly. It looks like it needs pushed out slightly to get that top bolt in properly. The hood helps determine how far out the fenders need to be.
Yes, the slot holds a hood bumper. An adjustable hood bumper should be on top of the grille shell.
Now I am going back to your build thread.
Fender are on for now, I'm sure some shimming once hood is on.
Grill is next
It looks proper to me.
But your bumper brackets are backwards. :D
Did you install the bolts into the fenders through the angle brackets? (The underside, rear)
Yes, swap those.
And I am giving you crap about the bumper brackets. I figured that you had them spun around to keep them from hitting a knee on them.
:waytogo:
I did have them that way exactly for that reason. but you definitely made me think a minute about it. I was like, "how else can they go" hahahahaah
