TXblueSS
Registered Member
Ok, I'm finally getting into replacing the floors on the Jimmy. I have the floor pans and outer rockers, and just ordered the inners. There is a LOT of rust, but it is limited to the floors in the driver's and passenger's tub.
The noobish question is: How exactly does the inner panel go in (location and orientation)? I have NO point of reference on the jimmy, as it is all rotted away.
Also, is the pan below that removable? I am going to do something to the under side of the floors when I am done with the metalwork (rust bullet, bedliner, or something else) What do you guys recommend?
