Input shaft question
Magikal
North Idaho
I'm putting together a doubler with a 203 205 but I need a 32 spline input shaft for two or three and I'm having trouble locating one. I was curious whether an input shaft from a 208 would swap into a 203?
I don’t think they’re the same. I know ORD shows them on their website but it’s 155 bucks...
Only a handful of these replies are contributing to the original question. I know ord sells them (way over priced, like everything they sell). As does northwestfab. I actually found a new one online for as low as $90.
I know they are available to purchase. I was just trying to see if any other input shafts would work also. Perhaps utilizing something i may have on hand.
If you were crafty and patient, you could do some machine work and make the input off another t case drive that gear. Might not be worth the time to you unless you already have a lathe
