Sorry, My first clutch replace
I left the bellhousing attached to the sm465 when I moved it back. Can the new fork & TO bearing be installed this way or do I have to remove bellhousing to install? I'm trying to do this the fastest way possible cause it's cold outside!
Thanks,
.I left the bellhousing attached to the sm465 when I moved it back. Can the new fork & TO bearing be installed this way or do I have to remove bellhousing to install? I'm trying to do this the fastest way possible cause it's cold outside!
Thanks,
