Installed new body mounts and 1" lift......after truck warms up, it wants to idle too low and seems like it wants to die.
It ran fine before the install.....and no codes are popping up. I checked all ground connections and wiring. And also checked fuel lines. I haven't found anything smashed or unplugged.
Is this a coincidence and maybe a sensor has failed or did I do something that I haven't found yet.
It's running at 13-14 lbs of fuel pressure so that hasn't changed. I get good spray at the injectors.
And it suprises me that it's not throwing codes.
Where to start? I'll run winaldl and see what it says.....maybe it'll throw a flag and I can start there.
And your suggestions?
