Installed custom tranny x member finally...
stallion85
Cedar City, UT
Well,
My stock tranny x member was severely limiting my breakover and constantly hanging up, twisting, bending, etc. I hated it! I was e mailing with a bud of mine Blair (SmashMetal) and he said just tell me the word and I will make you one:D
So of course I said sure, go ahead:bow:
I love the design and it will definetly help out where the stock x member failed.
I really like that one. My skid plate is bent up, so now it touches the 241, and it rattles like crazy. I don't think you'll ever get that problem. I want one!! It looks great.
Al
dont let that skid plate of yours there rub against the 241 cause it will wear a hole right in it like what happened to mine the skid plate rubbed right into the bottom of it so i had to get it tigged up
Nice "but"
Looking at this new crossmember i think its well worked but i see a little problem, i see that you have welled a Square piece to the Frame and looks king of odd, any plans of changing it to where it tucks into the Frame rail and not into bottom of the Frame. other then that good job nice design,
Just had to say some cause i plan on adding xmember but i want to show my Blazer at shows and might run into people asking the same ? i did
If you look at a factory x member and this one the frame mounts are superior. There are plates on the inside of the frame rail to help secure the connection.
I don't know why he didn't build it inside the frame rail for mor clearance, I have not seen many designs that do that, so I am sure there is som sort of problem with it.
This x member will do it's job and then some for my app:bow:
stallion85 said:
I don't know why he didn't build it inside the frame rail for more clearance
Not really sure why so many complaints of the 2 inches of lost clearance over the frame rails. Why hasn't anyone said anything about the 7-8 inches that the transfer case hangs down? Just my $0.02, but I think it's sweet and I plan on doing something similar in the future.
looks good
i need one
i hate my factory xmember to it was bent so far back that the front out put was rubbing on it
That's where the clocking ring comes in. I was going to get one, but after all the other mods that would have to be done, I am happy with just a better designed crossmember. This one is designed to slide over rocks, the OEM was designed to hang up on them:D
