Over the Labor Day weekend I installed a set of DIY4X front spring hangers, and U-Bolt plates. The main reason I took my Crew Cab apart was to install a new Dana-60 spring perch, which I also bought from DIY4X. I removed the entire Dana-60 from my crew cab, and cut off the old spring perch, which was collapsed, and welded on the new one. Then I installed the front spring hangers, and put the Dana-60 back in along with the new U-Bolts and U-Bolt plates that I got from DIY4X.
