installing 1-ton 14bolt in Blazer
hitechredneck
Registered Member
west virginia
Anyone know the distance between the spring perches on a 1-ton setup? Need to install the axle under a '90 Blazer. Thanks.
I got my new perches and rested them on the axle- bolted the axle to the leaf springs lightly and dropped a plumb line from the center of the truck and measured out to someplace on the backing plate or disc. Made sure all was even and checked d-shaft angle- with weight on axle and welded them in place.
