Installing a Breather
aknight_sa
Saudi Arabia
hi all,
is there a reason why someone will install a breather on the valve cover rather than routing a hose to the air filter?
when should that be done? and are there any benafits?
Thanks,?
Sure. Im runnin open element air filter assembly on my carb'd 84 K5, once you take off stock air filter box, ya have to do something with the breather.
I've run breathers on the rockers like Madmoocow...I mean badmix says with an open element filter but when it's hot and your moving slow you can get quite a lot that 'hot oil smell' in the cab.
There's another reason for me- In a rollover, if you route the breather hose up and around the motor to just below the other head, you will not puke oil from the valve covers when you are upside down.
