NEK5
3/4 ton status
those of you that have done it, is possible to DIY? Any tips? Would using the stock shims the way they are in there now be good enough, or is the dial caliper mandatory to check the backlash? Is there a way to do without using it?
TIA
EDIT: Also, I need one new bearing for it. Are the carrier bearings on the detroit the same as the stock carrier?
TIA
