Installing Rear Cap Seals
Justin Fleming
Oxford MI
So I purchased the new seals however there is no two sided tape or sealer to hold the seals in place. What is the trick here. What am I supposed to be using?
thanks in advance
Yes you will need some good weather adhesive. There is a good install on forum, let me see if I can find it for you.
I was unable to locate it on the forum. I figure this was common enough that a good write up would exist....
That is the one I was looking for there!!!! Should be a sticky for future use!
