Took out an old junk cooler and got an oil cooler and a gauge from a friend. I want to add temp switch to turn it on at 180 and turn it off at 170 (those are the only kind i've seen for sale)is this to low, will my fan always stay on? I also want to run a relay and switch to have on-off-on, so i can turn it reverse to blow engine heat on the cooler when its warming up in cold weather(don't know how i would switch polarity in the switch without running another set of pos and neg wires?), "off" in a water crossing. And need to run the oil temp guage.
Have heard running cooler by itself is not ideal, but don't have a cooler on the rad. Was thinking of splicing in before the cooler with two T's side by side. So I could run both of the temp probes next to one another just to make mounting the setup easier. Anyone ever done a setup like the one mentioned above.
Any input would be great.
Reversing the engine heat sounds preety doubtfull to me to, heard it on another forum and thought i'd try it. I'm not dropping the pan becuase i just got done buttoning up my TH350 with a new pan gasket and if something is off with the switch i'd like to be able to have access to it. Thanks for the wiring advice.
