Ned Kelly
I understand when installing a 1 ton 14ff into a k5/burb etc, that the 1 ton's axle spring perches are mounted more outward (or inward, can't recall), and that new perches need to be welded in the correct position.
Are the 1 ton spring hangers different? If I bolted the 1 ton spring hangers onto the burb frame, would that let me then just bolt the 1 ton axle in, without having to move the axle perches?
