Wanted Instrument Cluster
Are you looking because your gauges stopped working? I'm just asking because that's happened to me and it's real easy/cheap to fix.
No this one is cooked. Needs a new circuit board. I replaced the step motor a while back.
The only problem is, mine is not rebuildable with out replacing the board. A core charge is around $450 plus the rebuild charge. I found someone who will do the whole thing for around $400.....More than likely what I'm going to do. Just figured I would see if anything was on here.
