Instrument Panel connector question....
TheBeast_88K5
Banned
[Far away.]
Anybody know what the brown/white wire goes to?
I think it's brown.
It's not black or gray, and it's not tan, but it is dark in color.
I can't find it listed in ANY of the wiring diagrams I have. :dunno:
I think it's brown.
91 manual says it is the brake light/emergency brake tan/white stripe
In the actual manual?
My ass-hat neighbor stole my manual...
I've been going by online wiring schematics,
But, none make any mention of a brown/white wire.
The tan/white wire is labeled as the parking brake switch, in the diagram for the '87.
*The harness is from an '87.
Careful using a 90 or 91 diagram as the cluster and at least some of the wiring is different.
brown/white goes to 419 on ECM ECM says service engine soon
Iirc Rene installed an OE tach cluster in one and he had to do some repinning of the connector. :dunno:
Yer right....
The connection spaces, and wiring colors differ year-to-year.
Everything in the harness has corresponded with my '87 diagram.... 'Cept the wire in question.
Yer right....
currently running an 89 cluster in my 85 with no repin involved
I have a repin list from when I installed a 1979 dash into my 1990 K5 on here somewhere.
Martin
Light brown with white stripe - oil pressure
Dark brown with white stripe - SES lamp
Martin
This helps, and matches from what I can recall...
Tore into it today and figured out my problem. Had to add an additional ground for the Fuel gauge. The 1990 used one ground. The 1978 cluster (I believe it's a 1978 now, I just bought another tach cluster from a 1979 and it says UNLEADED FUEL ONLY under the Fuel gauge) has multiple grounds. The 1990 cluster has a better laid out ribbon, and it is also labeled better. Anyway if anyone is curious, here is a list of what pins are what wires after I wired it up in place of a 1990.
Old Cluster with Tachometer (1978 or 1979??? No mechanical gauges)
Pin # - Fuction - Wire Color from 1990 K5 Blazer
1 - High Beam Indicator - Light Green/No Stripe
2 - 12 Volt + Controlled By Headlamp Switch - Light Gray/No Stripe
3 - Ground - Black
4 - 12 Volt + Keyed To Ignition Switch - Pink/Black Stripe
5 - Oil Pressure Gauge From Sender - Light Brown/No Stripe
6 - 12 Volt + Keyed For Fuel Gauge - Pink/Black Stripe
7 - Fuel Gauge From Sender - Pink/No Stripe
8 - Ground (for Fuel Guage) - Yellow (I cut out the seat belt warning lamp for this, tied into the Black ground wire)
9 - Temperature Gauge From Sender - Turquoise/No Stripe
10 - Ground - Light Blue/Black Stripe (tied into Black ground wire)
11 - Left Turn Signal Indicator - Light Blue/No Stripe
12 - Right Turn Signal Indicator - Dark Blue/No Stripe
13 - Seat Belt Reminder Lamp - Yellow/No Stripe (I ended up cutting this out and using the wire/pin for my fuel gauge ground)
14 - 4x4 Indicator (there was a separate wire not part of the 18 pin connector, I have a doubler, so I did not use this)
15 - Choke Indicator - Dark Brown/White Stripe (Is now my Service Engine Soon lamp)
16 - Ground - Dark Brown (tied into Black ground wire)
17 - Park Brake/Unequal Brake Pressure Indicator - Light Brown/White Stripe
18 - Not Used
Here is how the 1990 K5 was originally wired up with the factory electronic speedometer:
Pin # - Function - Wire Color
2 - Ground - Black
3 - Oil Pressure Gauge From Sender - Light Brown/No Stripe
4 - 12 Volt + Keyed From Ignition - Pink/Black Stripe
5 - Low Voltage Warning Lamp - Dark Brown/No Stripe
6 - Not Used
7 - Not Used
8 - Coolant Temperature Gauge From Sender - Turquoise/No Stripe
9 - 12 Volt + Controlled By Headlight Switch - Light Gray/No Stripe
10 - Left Turn Signal Indicator - Light Blue/No Stripe
11 - Right Turn Signal Indicator - Dark Blue/No Stripe
12 - 4x4 Indicator Lamp - Separate wire from 18 Pin Connector
13 - Seat Belt Warning Lamp - Yellow/No Stripe
14 - Fuel Gauge From Sender - Pink/No Stripe
15 - Park Brake/Unequal Pressure Warning Lamp - Light Brown/White Stripe
16 - SES (Service Engine Soon) Lamp - Dark Brown/White Stripe
17 - 12 Volt + Keyed From Ignition Switch - Pink/Black Stripe
18 - Speedometer From Sender - Light Blue/Black Stripe
Martin
Well, I think I found it, but still don't know exactly what it does.
Looks like its some kind of option, and one label calls it a 10 ohm resistance wire.
Its the dotted line in the two instrument schematics.
There is also a brown/white wire in bottom of the computer schematic that goes to the brake switch.
The funny thing is... I'm not converting anything. :haha:
I just needed to know what the wire was,
cuz I'm replacing the gauges and harness.
The rest of that info is SUPER helpful, tho.
:waytogo:
