Float or the capacitor on the back of the fuel gauge on the cluster....
It is the one that was in the K5 when I purchased it, I was doing a clean up overhaul lens change bulbs etc... The one in the vehicle now is the one that was in the vehicle when I bought it last year. The one in the photo is one I purchased for parts, I was going to check it before pulling the panel out againWhat were you doing with the cluster when you had it out?
The fuel gauge that is acting up, is it part of the used cluster that you purchased or is it your original fuel gauge?
I once had that gauge resistor go bad (i think it cracked), it caused my fuel gauge the only go up like 25%, would never go past quarter mark. But it absolutely did not affect anything while driving. I think I have a spare if you want to try the resistor anyways
I was thinking my float was the issue because the needle goes up when going up hill also during acceleration, then drops when letting off gasIt is the one that was in the K5 when I purchased it, I was doing a clean up overhaul lens change bulbs etc... The one in the vehicle now is the one that was in the vehicle when I bought it last year. The one in the photo is one I purchased for parts, I was going to check it before pulling the panel out again
Thanks working tomorrow will check Wednesday my day offThe resistors are calibrated. You need to match the color to match resistance. Thus far I haven't seen different colors with the same resistance value.
Yes, you'll need to look at resistance. It shouldn't be infinite (there is a break between the connection on either end if so).
If you have two resistors, and different colors, if they are both good, you should see a difference in the resistance. Usually (every time?) you will see a crayon marking on the housing (silver piece) that I believe somehow correlates to which resistor was to be used.
I Didn't think of that, I will definitely do that instead of pulling out that cluster again.If you still have your cluster bare like that, it's super easy to swap out the fuel gauge for testing. You have to remove the clear plastic as well as the black frame, then one or two screws for the fuel gauge itself and it pulls straight out. You do not have to pull out the entire cluster again.
Rather than swapping resistors, I would just plug in the other gauge and see if it does the same behavior. also wondering if maybe theres a loose connection somewhere, since you had the cluster out....
One of my old C10’s always said 1/4 tank when full and empty was empty... I never fixed it, Just keep track.
Thanks again for the tip taking the plate off the front made it much easier. I tried changing the fuel gauge on the right with the one from the left in this photo it did the exact same thing on acceleration or when the trucks uphill the gauge goes towards full. The gauge with the pink resistor? Reads slightly lower eighth of a tank less but moves the same amount
