Intake for TBI with Vortec heads
wayne
3/4 ton status
Carlisle, Pa
I did some checking and here is what I found. Edelbrock is not planning to make one at this time. Good news is that you can get one from GM Performance for $395.00. Just thought all of you might want to know.
<A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
<font color=blue>Happy Trails
</font color=blue>
<font color=blue>Wayne</font color=blue>
Does anyone know if the manifold fromk GM is made for performance or just a stock replacement that they made to fit?
90K5
See my truck at <A target="_blank" HREF=http://albums.photopoint.com/j/Albumindex?u=1329584&a=9886502>http://albums.photopoint.com/j/Albumindex?u=1329584&a=9886502</A>
Did not get a part # because you can get it from your local dealer. You might even be able to get a better price too. It should work fine with any setup as far as performance goes because you are going to be limited by how far you can go because of the TBI itself.
</font color=blue>
These part numbers were posted a few months ago here on CK5. Trust, but verify.
TBI Vortec Aluminum Intake Manifold GM P/N 12496821
Vortec Exhaust Manifold GM P/N 1257828
Other parts necessary for the EGR Modification:
- EGR Tube GM P/N 10220275
- EGR Fitting GM P/N 12552329
- Vacuum Controlled EGR Valve GM PN 17052693
'89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
Here are the prices from <A target="_blank" HREF=http://www.sdpc2000.com>http://www.sdpc2000.com</A>
1. Fitting for use with Vortec EGR Supply Tube 12552329 $4.08
2. EGR Supply Tube 10220275 $52.31
3. Left Hand Vortec Exhast Manifold 12557828 $80.25
4. Vortec TBI SB Chevrolet Intake 12496821 $329.95
