Intake gasket set
Clod_King
Grimsby Ontario
I picked up an intake gasket set the other day because I'm pretty sure I am getting a vacuum leak there.
The kit I got (Fel-Pro MS 93371) came with two gaskets for the dizzy... I only know of one that actually goes there. Is the other one for different setups, or is there an actual spot for both of them??
Should be one gasket between distributor and manifold. Check for oil pump binding without the gasket if it bottoms out before contacting the manifold you will need some shims.
