I was told that if you don't use a manifold with a rear coolant crossover, that the rear cylinders would run hot. Is this true? If so, can I drill/tap and run a hose between the rear of the cylinder banks on a performer manifold?
Also, steam holes on non-400 heads? Do I just drill holes into the head using a 400 head gasket as a template?
