I am installing a turbo on the 6.2 and wanted to know how you all plumb from the turbo to the intake manifold? what does the stock set up look like and have any of you been creative with it?
ssped said:I am installing a turbo on the 6.2 and wanted to know how you all plumb from the turbo to the intake manifold? what does the stock set up look like and have any of you been creative with it?
Can't help you there.ssped said:It is the factory 6.5 turbo. I am getting the manifold and turbo only.
but it was fun to drive till it went.ssped said:I think this is going to be a little creative upgrade on the truck. The more I read the less I know. gota love a challenge. The last turbo I did was on a Honda civic. we kept bowing head gaskets on the damn thing pumping 20lbs of boost in it.but it was fun to drive till it went.
ssped said:I looked and they are all over ebay. I am also(once the turbo gets here) going to look at the local yards for parts too. From what I have read I heed to make spacers for the manifold to move it out a half an inch to clear my injectors too since I am running an 82.
you may or may not need to space it out some, i have read a couple articles of guys doing exactly what you are trying to do. the turbo does come close to the injectors but it seems to vary on how close, i would get the parts and mock it up to see, then maybe decide on how to make more room if you need it. I would see the easiest way being having a shim made to space the turbo 1/2" from the manifold, you might need slightly longer studs to bolt the turbo down, but that should give you plenty of room. I'm just not sure if you even need to worry about it.ssped said:So am I right in the research, I eigther need a couple of short injectors or space out the manifold?
