Intank fuel pump
pomai
Oahu, Hawaii
What fuel pumps are you guys running?
427ci FI.
25 gallon fuel tank
If possible, part numbers also please.
Thank You
That's the one I was thinking about, but I was concerned about it fitting in the sender housing. Thank you
I run a set of EP377 (33 PSI max) Delco's in my saddle tanks. With the TBI adjustable fuel pressure regulator set to 13-PSI.
ep381 is a 1996 c3500 chevy truck 350 vortec pump . it clips direct in no custom parts or wire redo . fuel sock also clips direct on from tbi style pump . gets you 60ish psi to cover about most all systems and good flow for most guys .
Edelbrock pro-flo xt intake and BS3 (BIGSTUFF3)FI Management system.
