interchangeable d44 parts
73redblaze
Aptos ca
i have two front dana 44 axles, one is a 1/2 ton and one is a 3/4 ton. I know i can swap the knuckles but can I also swap the rotors and brakes? what else can i swap on these? and is a 10 bolt any diffrent? Thanks guys Also has anyone ever drilled their own rotors for better stopping power?
There are two sizes of spindles; IIRC, as long as the axles are of similar years you'll be fine.
10-bolts have the same spindles, hubs, brakes as equivalent later D44's -- the split is in the mid-70's IIRC.
-- A
