Amahoser
Registered Member
Im not totally sure if I have a part time kit or not since i've only had this Blazer for a week. It does have manual hubs so I just assumed it had a part time kit.
When I bought the truck, the PO only had it 3 years and he was not very familiar with the 4wd system. He pretty much kept it in 2wd mode. The transfer case was stuck in 2wd when bought.
I unstuck the transfer case last week by cleaning all the grime and wd-40'ing the linkage... ok figured that would solve it. At that point, I could shift from 2wd high - neutral -2wd low. But that was it.... so I guess I wasn't done yet.
After reading a few posts on this site, I decided to try to adjust the linkage. I found that the inner most lever on the transfer case was angled forward (towards front of truck) when the shifter was in neutral. I reset the lever and adjusted the linkages.
Now, the transfer case behaves like there is no part time kit installed.. When hubs unlocked...
Low Lok - drives
low - truck don't drive
N
High - truck don't drive
High Lock - drives
Seems odd that someone would install manual hubs but not the part-time kit.
Questions....
- CAN the linkages be adjusted in a way that there is only 3 positions (low lok, N, high lok)? Is that what was done to this truck???
- IF I do have a part time kit, could mine be broken in a way that makes it act like it doesn't have a part time kit?
- running in high lok with the hubs disconnected is fine right?
- IF i do have a part time kit, is there a ritual or a procedure that needs to be followed in order to switch from 4wd to 2wd mode??? (like drive it in reverse for a bit or doing a 2wd dance outside the truck before unlocking the hubs)
- what is that dance (I have no rhythm, btw)
Jose Soriano
Low Lok - drives
N
High Lock - drives
Questions....
Jose Soriano
But to be safe, i'll just drive with the hubs engaged and in High mode.
