So I recently added 2 relays to supply my ignition switched components to my fusebox. (if curious why, go here: http://coloradok5.com/forums/showthread.php?t=310188) One supplies the pink wires, the other the orange wire that supplies the PW, A/C. The one to the orange wire is a supplement, meaning that the original wire stayed connected at the fuse box, but I tapped it to trigger the relay, and then new power is fed to the same fuse buss. The relay supplying the the pink wire is not a supplement. It solely supplies the power there.
The problem: the "orange" relay remains engaged after the key is off. I can run my fan and windows with the key off. If I disconnect the trigger wire, it shuts down the relay and won't re-engage when I plug it back in (there is not 12v at the trigger wire).
I swapped relays, same thing. Check this out though...if I switch the two relays' trigger wires, both will operate just fine (how I have it now). It only remains engaged when the trigger wire is on 85 and the 87 wire runs to the buss where the trigger wire is tapped (and the original wire remains).
I think this "loop" must have something to do with it, but how?
Here is a pic of the buss. The brown runs to 85, the red is from 87, and obviously the orange is the original.
