If anyone cares, got an interior dB number out of my truck. 103dB max. Number is under pretty constant throttle conditions, not when I was flooring it. Speed did not seem to matter too much. Random testing outside the truck at idle indicates it's louder inside than out.
It's a "cheap" Scosche SPL1000 (http://www.amazon.com/Scosche-SPL1000F-135DB-Max-Meter/dp/B001CMKFH8) so no idea how accurate it is in general, but I have already compared it to my car under same conditions/speed (85dB) which apparently is inline with "normal", so I have a baseline to compare against. It's a cheap older econobox so it is probably louder than a more expensive car.
Truck has nothing for interior that will likely affect sound: no headliner, dash pad, carpet/sound deadening. Exhaust is the stock dual pipes (for the most part) from a 6.2L spliced into headers, with no muffler on one side, and a muffler on the drivers side with a hole in the side of it. Both exhaust pipes "exit" behind the rear tire in the stock locations, but obviously the holed muffler does a pretty good of venting exhaust.
I do not like the sound. Fixed the problem that led to the blown mufflers (bad fuel pump hose in tank) but drive the truck so little that I haven't had the motivation to really dig into the exhaust, which is intended to be stainless, from the headers all the way to the back.
..when its nice and warm out maybe I'll deal with that issue then...getting my leaking oil pan replaced is a higher priority ..
I'll be replacing all the door seals soon to try and help that area.
