ok so after swamping my truck, I removed my seat and cleaned out the peanut butter mud. Man was it everywhere... I then proceeded to Rustoleom bed liner in can the inside. I did the floor and it came out pretty good (2 cans). I then last night did the door panels (1 can).
now my truck is a toy.. 3rd vehicle and if breaks can sit so I haven't really finished certain things like putting screws in LOL...
so I have lost all the screws for the gauge cluster cover (to which I need a new one as well)
I also noticed that when I painted the door panels I only had 1 nut holding the pad to the panel. It is hard to explain but if you've seen it you know it.. the bolt is attached to the pad on one end and has the stud where you put that nut that self taps onto it...
so while googling, this got crazy as I see screws for $.25 each to kits...
so has anyone got a good place and what kits work well?
I need all screws for gauge cluster
screws that also go into the pad through the panel (not sure what size it is)
screws that go through pad/panel into metal bracket on door for arm rest
screw that goes through panel where door handle is (that recessed pull bar)
all screws across bottom that screw through panel into the door
I found this and they have kits but I'm lost.
https://www.classicindustries.com/s...arts/interior-hard-parts/interior-screw-kits/
