interior trim color?
TheRealJimmy
Registered Member
Dawsonville, Ga. 30534
My interior is grey, but what color grey? which one of these numbers in the interior trim color code? I know the exterior one is the U8867
What Year ? The exterior RPO Color should be in the upper area of the label . The lower number your are referring to may actually be your interior numbers.
Also, pending the year, the Inside upper half was Mystic (Whiteish color) according to a lot of my research with the Headliner and Headliner trim being the same color.
At a certain point, the upper body interior area also was paint matched. i.e. headliner and trim was same color as seats and carpet.
See this link and find your Vehicle ... it will give you everything you want to know about the RPO codes ... and a nearly everything that was included in the sales booklets.
I attached my 85 so you can see the information...
I hope this helps !
Did you figure out your interior colors ? I could not sleep and needed to research my 1985 Color in my Blazer for restoration ...
The numbers at the bottom are your paint codes for sure and seeing the Code 82D next to them and in the RPO codes up above with 82I
I going to guess it is called Slate Grey based on the brochure.
By the picture you have the Deluxe Two Tone Package ZY4 and according to your codes you do.
The RPO Codes above show.
83K is going to be your Grey Fiberglass Top to match the body center color "Color 2" / Look on the line under the chart for Top RPO Codes
96U is going to be Body Color 1 Quicksilver Mat.
83L is going to be Body Color 2 Gray Met.
See Page 20 of 20
Also you can see all of your RPO codes throughout the document .
Here is the Paint Color Web Page I keep in my research which confirms the codes you already know. IF you search for GMC colors you only get the cars
Another web site.
It appears there are two #82 in the RPO codes and there are two Gray's in the Color Chart for 1990 Medium Dark Gray and Dark Gray.
This is from SEM... probably the best .
See page 1 in PDF
Enjoy your weekend
