SLO C5
If I am at a stop sign(or moving slowly) and turn the wheel left and accelerate I get this loud noise. It does not happen when going right. It seems to be coming from the front of the car, driver's side. If I am doing this over a bumpy road the noise seems to change volume with the suspension oscillations(for 1 or 2 seconds). It's only at low speeds. It really sounds like tires rubbing, but I know this is not happening since it occurs even when the suspension is not compressed at all. Clearance is not an issue, my Sub has a 10" suspension lift, 2" body lift, and 39.5" swampers.
This morning on my way to work it was doing it when applying the brakes at a very low speed. And when in gear with the brakes applied(and car stopped), the noise was audible as well.
After driving for a while on the freeway, then back in areas where there were turns and stops the noise went away.
From the noise this morning it seems brake related, but usually I first noticed it while accelerating. Could it be something with the master cylinder/vacuum system?
Also, the brake pedal seems to make a lot of noise when I press on it. It almost sounds like air rushing out of tires, just not as loud.
