73 K5 Blazer
I have an 82 K20 with a 454 / 400 combo. I am having an intermittent starting issue. I drive this truck on the weekends and it has been acting up for the past few weeks. So today I am going to take it over to my friends shop to get undercover just in case Gustav makes it up to Jackson. So it is parked beside my shop and I went to fire it up and it turned over with no problem gut stalled out and than would not crank. When you turn the key you get nothing from the starter. Everything else works fine and the battery has a full charge. Before I pull the starter I figured I would see what ya’ll think the problem is. I am leaning toward an electrical issue. There are 2 wires going to the starter, the pos cable to the battery and the wire going to the ignition. I need to see if anyone has a wire diagram or some input.
