bp71k5
3/4 ton status
I'm installing a 1000W(2000W) power inverter. My plan is to install it on the passenger since it's close to the battery. The problem is that
my alternator is on the drivers side. Since I plan on keeping the engine running when I use high power electronics like the stereo and the inverter, ( to let the alternator supply the bulk of the power rather than draining the battery), shouldn't I upgrade my alternator charge wire to the same size as the power lead for the inverter? The instructions say minimum 4ga wire.
