Just picked up an IR air saw (model 429 IIRC). It came with a small assortment of 24tpi and 36tpi blades.
Those seem to be fine for thin, clean sheetmetal cuts but I was wondering if there is a coarser blade that might allow me to cut 1/8" or larger steel plate.
I've searched a bit online, but 24tpi seems to be the coarsest blade they make.
Depending on how well it worked it could cut brackets much closer to the final dimensions I need and spend less time doing all the finish work on the 20" grinding disc. Free handing cuts with the plasma cutter leaves a substantial amount of extra material that needs cleaning up.
Just brainstorming to come up with a faster way to get my parts built.
-G
I've searched a bit online, but 24tpi seems to be the coarsest blade they make.Depending on how well it worked it could cut brackets much closer to the final dimensions I need and spend less time doing all the finish work on the 20" grinding disc. Free handing cuts with the plasma cutter leaves a substantial amount of extra material that needs cleaning up.
-G
As you can probably tell I'm getting really fired up about the steady forward progress of my build lately, so I want to find ways to make the most out of my shop time.
