Hello new here from Phoenix AZ. I sold the first Blazer I owned in 1990-91, and finally almost 30 years later have purchased another Blazer. Having driven fuel injected vehicles for a long time and having great luck with Iridium spark plugs, just wondering if anyone out there is using Iridium on their carbureted K5s. If so, did you notice any positive/negative effects. Thanks in advance for your input.
My opinion.
Assuming you replace your spark plugs at least every 10k miles;
Iridium plugs are not neccesary.
Now if you have an oil burning engine.. iridiums are even more unnecessary.
Just use cheap plugs in an oil burner.
Honestly, a spark is a spark.
No benefit to fancy electrodes except in very specific applications and truck motors are not one of those.
For instance:
Arctic Cat TZ1 snowmobile.
You have to practically disassemble the engine to get to the spark plugs.
Iridium plugs will erode less and last longer than conventional plugs.
Therfore, the extra cost makes sense.
Or you just do not want to lift the hood for 30,000 miles and have attached a tube and funnel to facilitate oil changes.
Or you just want to run you plugs until the electrodes wear all the way down to nothing.
I saw that once.
Ford Aerostar van had over 100,000 miles on it's spark plugs.
There was almost nothing left of either center electrode or ground arm.
It ran poorly, but it did run.
But you are here on CK5.
You will keep your Honey in good tune.
You will be replacing plugs before 30k miles anyway.
You will get more horsepower by cleaning the windshield.
