P puckhead 1/2 ton status Joined Jun 17, 2005 Posts 112 Reaction score 0 Location colorado Aug 10, 2005 #1 Are all 8 lug wheels the same bolt pattrern?
P PDXCHVY Registered Member Joined May 18, 2005 Posts 11 Reaction score 0 Location PDX Aug 10, 2005 #2 Newer Ford Superduties use a metric 8-Bolt pattern. Other wise yeah it's a pretty standard pattern 8x6.5
sled_dog 1 ton status Joined Sep 3, 2002 Posts 16,867 Reaction score 3 Location Austin, TX Aug 10, 2005 #3 no there are 2 different standard 8 lugs. 8x6.5(GM Dodge, and Ford until 1999) Ford went to 8x170mm(I think thats the measurement) in 1999, so those wheels will not fit on anything but a Ford F250 or F350.
P puckhead 1/2 ton status Joined Jun 17, 2005 Posts 112 Reaction score 0 Location colorado Aug 10, 2005 #4 DRAG it is in fact a 99-04 sd thought I had a set of wheels and tires for 125.00
boggerless 1 ton status Premium Joined May 26, 2003 Posts 23,088 Reaction score 378 Location dearborn heights, Michigan Aug 10, 2005 #5 at least you checked first.i had to drive six hours to exchange mine. sd's are two coats of paint from fitting.
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,032 Reaction score 25,499 Location in the back of your brain Aug 10, 2005 #6 leave it to ford to change it up and go 8-170mm dont forget the 7 lug setup thay have that was real smart thinking.
