blackandgold51
Huh? I mean its an overdrive trans. Its the fourth gear and designed to be used as so. The only time using OD it bad is if you lift a truck, put bigger tires on and dont regear it and it constantly shifts between 3rd and 4th on the highway.
The tires i have are about size 15s that are 33s to 35s and thats it.There is no scenario in a stock vehicle where you shouldnt use all the gears...
If you didn't regear the differentials to a higher number then you will burn the trans up using 4thThe tires i have are about size 15s that are 33s to 35s and thats it.
Vehicle is 1990 Suburban V1500
Even not bad driving in overdrive through the stop amd go city amd interstate ? Mixed city drivingFlatland overdrive is fine, in the hills or pulling stay out of it. High speeds will kill it to if its shifting alot.
We smoked many transmissions in Caprices before we changed our ways.
My understanding is if the 700r4 isn't locked up it's making a bunch of heat. So I don't think there's going to be a problem as much driving in 3rd as much as you want that torque converter locked.
