F foolhardy Registered Member Joined Sep 16, 2004 Posts 84 Reaction score 0 Jun 7, 2007 #1 is it normal for your truck to run 15 or 20 degrees hotter with the a/c on
T turdmagnet Registered Member Joined Jan 5, 2007 Posts 42 Reaction score 0 Location colorado Jun 7, 2007 #2 Every vehicle runs hotter with the A/C on.
lectric80 3/4 ton status Joined Apr 4, 2007 Posts 9,704 Reaction score 219 Location Grantsville, Ut Jun 7, 2007 #3 Yes, the air that passes through the radiator is heated by the condensor in front of the radiator. You will always run hotter with the A/C on.
