I have a 83 with a 6.2 engine . I have had a terrible belt squeal with the Alternator belt . I replaced the belt and the squeal went away and it stopped charging . Found a bad connection on battery post of the alternator . Replaced that still no charge . Decided to have the alternator tested and found it was charging but had a bad bearing . Installed alternator and replaced belt and it was charging !!! I ran it for a few minutes and went to check belt and pulley and alternator whas so hot it burned my fingers !!! Do alterators get this hot ? If not then why is this happening ? The alternator was the same way .Now my belt squeal is back also after running it Thanks !!
