kj1963falcon
Hi
I have a 75 truck with a big block and a Holley 4118. The only info that I can find on the web says that this is a 730cfm carb.
I am a having problem at anything past half throttle. The truck starts up and runs fine, and as long as I keep it under half throttle or about 2500 rpm it is smooth and quiet. When I go past 1/2 you can hear a loud sucking noise and if it is cold or going up a hill it will backfire through the carb.
I have been using the search tool and reading about people who had the same problem on the board. I checked the compression and the firing order and they both look good. The plugs were fouled so I went and got some new ones that I will install tomorrow. The PO installed a HEI and I checked and it is getting over 12 volts at startup and when running.
I think that I may have found part of the problem I found a kinked fuel line right by the fuel pump that I am going to replace tomorrow but I am worried if I have already caused damage to the carb with the backfires.
Is this carb worth rebuilding or should I just look into getting a new one and see if it solves my problem
