GsxrMike
I installed a steering shaft off of a cheap jerokee tonight and I am not sure if I did it right. The shaft is in but I don't know if the two shafts are suppose to move in and out of each other as my frame flexes. I can't pull them apart real easy but I can pull them apart. I read somewhere on here that you have to shorten the shaft a bit but I had to lengthen mine a bit. Can anyone tell me if this looks ok.
