Metal Twister
I put a new to me used 350 chevy in the k5. I also installed a new oil pressure gauge which at best reaqs about 10 psi. At idle it drops down to about 5 lbs. Can a oil pump get weaker? I was under the impression that they would wear out and just quit, but can they get loose and loose pump pressure over time?
thanks
Thanks for the help guys
