I've noticed the last few days typically in 3rd gear or above the truck starts having a problem.
At first I thought the transmission was shifting between gears or hunting gears. The rpms sound like they are changing 200-400 rpms a second like it is reving up then down then up then down literally like you were switching a lightswitch on and off.
I checked the fluids a few months ago and I'll check them again soon, they were fine no bad color or smell with the transmission fluid. The only other thing I notice is that sometimes when I first start the truck it doesn't go into reverse right away. I'll have to let it idle for a 20-30 seconds then it's fine.
The truck is on 35's, 4l60 trans, stock 350.
Any ideas?
Update. Unplugged drivers side connector. Drove really nice. Before it did not use 3rd much just for a sec then to 4th. It seemed to use all gears just fine now. None of the issue with rev up and down etc. What's the issue?
Any ideas?
