Is rear noise normal
Samhenley06
Registered Member
Huntsville
I just swapped 14 bolt ff with 4.10 gears it roars at about 65mph and I feel some feed back when I release the throttle.
If you went from 3.08 or something without vibes, your driveshaft is spinning faster now. It could very well be shaft angle vibes. If the pinion bearings are tight, my next suspect would be the angles.
