Talk to Tom (4by4bygod) he has the perfect solution for all your lube needs
http://coloradok5.com/forums/showthread.php?t=192545
Thank You Glenn ( not forgetting you either, Brent).. the thing about synthetic this versus dino that is that nowadays, ( thanks to the castrol court case ) anything can be legally called a synthetic. It's a marketing term, not an indicator of performance.
used to be, all synthetic meant was " highly refined" - all "highly refined" meant was that each molecule was "synthesized" to be the same size..that's why cheap oils "glop" when you pour them, ( varying molecule size )and real synthetics don't. they were also a superior oil for this reason. the oil got where it needed to go much more quickly, and you got a bit of a friction reduction.
FWIW, all lubes are petroleum..the difference is in point of origin in the carbon chain, and level of refinement. for example, PAO synthetics come from liquid natural gas molecules. mineral oil comes from the ground in carbonaceous liquid form and is refined into something useable..these are your group I, II, and III petroleum oils. Esters are a group above PAO's on this scale.
what's more important than labelling or marketing is formulation.. PAO oils without adequate esters will attack seals and cause leaks. both PAO and ester oils attract moisture.. even if you have the perfect balance of PAO and ester with no leaks, high heat will render the basestock unable to hold onto the EP additives ( and even they vary in quality and ability ) for any length of time, and any shock loads will hurt the lubricant as well. PAO's are not known for their ability to hang onto their additives.
Moly is especially susceptible to being " shattered" when a shock load is applied to a lubricant, and guess what oil companies are using to replace zinc, sulfur and phosphorus? sinterable metallics are not the answer.
for gear oil, you might be looking at a group II or III basestock, and that's just a mineral oil, that may not be refined to the point where all of the molecules are the same.. they're easier on seals, but they're not so good for reducing friction - unless you additize the crap out of them, and again, the amount of heat the oil can absorb will dictate how successful the additive is in doing what you want.
ester base gear lubes are nice on seals, but again, they do attract moisture - that's a big deal to some folks. the more expensive gear oils will have better tackifiers ( you don't want crap like lucas in there thickening everything ) but as always, heat is the enemy of additive retention.
important thing is to check out specification and msds sheets, and know the marketing from the science..
as always, you guys can buy what you want - just know what's going on with what's out there. If you want to see the next step beyond synthetics,as glenn says, the answer is just a click away..
