Is that limited slip?
Dabbas
Jordan
the limited slip has clutch plates and springs that can and will slip under harsh conditions. I'm not positive about how the gov lock works but I know its a mechanical lock instead of clutches
Yeah i know, i mean by looking at the axle , how can i which one i have! Btw thank u for reply!
you can see the springs in a limited slip. most look like a normal open diff. but have the clutches n spings inplace of the spider gears
Not a Gov-Lock in that picture, in fact it appears it might be a Detroit inside that open carrier. It's really hard to see with the glare from the flash, but I think I see Detroit springs through the window.
You can tell it's a 4 post cross at the very least...which eliminates the Gov-Lock as a possibilty. The Gov-Lock carrier has a three post cross.
that part I didnt know, thanks:thumb:
There are other ways to tell, but that one is the easiest. 3 bolts between the posts on the cross is the standard carrier which may be open, or contain a Detroit, or a Lock Right.
4 bolts between the posts, it's a Gov-Lock and nothing else.
if the carrier has windows and you see gears = open. if you see spring = detroit locker.
and fyi detroit locker is the best option for factory bolt in.
and by looking at the carrier in the pics its 4.56 -up gears. so must be from a military truck 1 ton = great score.
and here is a write up on the 14ff carriers with pics. http://coloradok5.com/forums/showthread.php?t=151608
i told you already but here ya go again. and to be super spcific thick
" and by looking at the carrier in the pics its 4.56 -up gears. so must be from a military truck 1 ton = great score. "
