is the 7.4ltr a 454?
google
Arizona
I found a local parts truck BURB with a 7.4 ltr V8.... is that the 454?
Dunno. At this point, it's a no wheel drive. It's a completely gutted 88 GMC burb. Has motor... dunno about tranny yet, and it's a 3/4 ton with it's stock axles 8 lug. What axles do 3/4 tons come with? What would it be worth in anyones openion? That's about all I know so far.
Crud, so not even the makings of a good trail project..... Would the body fit on my 81 Blazer frame? My Blazer is MESSED up bad as far as the body goes. Being that there will prolly be NOBODY buying this suburban, I can get it for a buck tomarrow.
i think the 454 ONLY came on 2wd burb, so it is a give away.
as far as the body fitting i would hate to see that happin it is a mint body and mine is so rusted out.....
the truck is what 3 feet longer that a blazer, and the body mounts are different.
you could cut it down and re weld it, search for user 'short sub' he choped his burb to look like a 4 door blazer, but you would have the work of getting it on the blazer frame.
is it cheap? anything you could part out? if you can ship the bdy to canada for cheap ill buy it:grin::grin:
