Is there a correct name for these fuel fittings?
shady
1 ton status
iowa
I'm trying to find adapters, or something so I can lengthen them and adapt them to my truck.
I'm trying to get to a Barb fitting for now. Or just a short length of hard line I can get hose over
I'm converting the pickup inside to a carb style for now. And I don't want to cut the fitting off because of a possible FI conversion later.
I could go AN and run hose from that :thinking:
14mm x 1.5 o ring tube nut. Lots of fittings to adapt. An is easy. Pm Heath.
Looks like you might need a double female adapter then run a male barb fitting.
You’re doing good, keep looking and you’ll find that
I envisioned a F\F -6, then a M\M barb, as the Fragola is a male end
I had to reach way back in the file cabinet for that one. It was a long time I bought those fittings to not use. :haha:
I have them listed in my build thread, but you got to it before I went digging!
I think Rick can handle it from here. He got the main sizes he needs.
I would just run the an line. It's easier that all that adapter crap.
It’s not cheap. But after going with AN lines, I don’t care for rubber hose stuff
I'm going to see if I can find anything in town tomorrow. Hoping to make it run.
I gotta find submersible fuel line too. If I can't find any of the stuff then I'll order up what I need.
Thanks. I just wasn't sure if there was a certain name for em besides O-ring .
Figured if there was it'd make it easier to find at the parts store.
You can get the repair sections at some auto parts stores.
I have NEVER seen GM literature that calls them "XYZ fitting". Some will call them a Saginaw flare.
They used to be impossible to find, but you can now. The Mastercool Hydraulic Tool Kit will make these as well.
